Old 10-04-2018, 12:10 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Default Eliminating fuel pump
On an 82 series tractor, don't they need a fuel pump to run as the tank sits lower than the carb? Would it be fine to replace the fuel pump with a 1-3 psi electric fuel pump or 3-5 psi one? I'm going to be in an engine without one.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 10-04-2018, 12:16 PM
If you don't live on a hill side and keep it above 1/4 tank you will be fine. I ran an 1811 without one for a few years.
Old 10-04-2018, 12:18 PM
Mudrig150's Avatar
Well, a good portion of our farm is hills.
Old 10-04-2018, 12:25 PM
IF....you want to run an Electric Fuel Pump, this has worked well..
Old 10-04-2018, 12:32 PM
What's wrong with a mechanical pump?
Mudrig150's Avatar
Still have't figured out how they work. do they go into the tank and have a line coming out?
Old 10-04-2018, 12:36 PM
They're in-line. They come with directions.
Back to my question: what's wrong with a mechanical pump? No wires, last a long time.....
Old 10-04-2018, 01:15 PM
Gompers Gompers is offline
I run electrics with check valves on my main workers because I trust them more than mechanical ones to not leak into the crankcase. That’s a pretty common thing on KTs and Mags. Can’t speak to mechanical pumps on k-series but I don’t think those are as common on cubs. . You can also make an adapter plate and run a vacuum one.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 10-04-2018, 01:42 PM
It's only a common problem after the engine/fuel pump is 25 years old or has a but load of hours. I bought my 1811 in 2002 with about 1300 hours on it. Motor was new at 1175. It now has 2100 hours. I've put ONE fuel pump on it. To me that isn't a bad enough failure rate to justify wiring up an electric pump that may last 10 years if you're really lucky. Failure rate on electric pumps is higher than mechanical.
Old 10-04-2018, 02:10 PM
Fair enough. It's just a peace of mind thing for me. I know that's one thing I (probably) don't have to worry about happening.
I also like that electric pumps can "pre-prime" the carb without cranking the engine.
I think I like the vacuum pump the best of all of them, though, since they are super cheap (and easy) to replace compared to the other two options.
