Old 07-16-2010, 12:16 PM
jrob33 jrob33 is offline
Default '73 149 Progress Pics (barely)
This is the drained and mostly cleaned transaxle. Still a bit of crap in there, i'll clean that out soon. I hope the gasket is cleaned off enough from the cover plate. Here is previous post with the before pics too.
J Rob
http://www.onlycubcadets.net/forum/s...ead.php?t=5038
Old 07-16-2010, 12:56 PM
ihnick's Avatar
ihnick ihnick is offline
wow. the before and after pics are crazy. my 129 was like that also. nice job
Nick.
Old 07-16-2010, 01:13 PM
Nice job, J Rob! Keep up the good work.
Old 07-16-2010, 11:40 PM
Nice work jrob33
Old 04-15-2014, 01:02 AM
Default Rewiring the 149 - Continuity everywhere!?
Allrighty everyone. It has been about 4 years since I posted last and the 149 runs great. I have used it to mow my 1/2 acre in northern new mexico for a couple years and for plowing and tilling. I replaced the rear tires (original turf tires since 73 with tons of plugs) with Super Lugs; that made a world of difference for plowing. My granddad used to get stuck all the time with those turf tires. Recently I even helped my neighbor move a lot of gravel with my box blade. But all this time I have not corrected the inferior/incorrect battery - s/g - v/r - wiring. The tractor has not charged this entire time and enough is enough.
After shooting lots of wires I have decided to just rip out all the wiring and replace.
Before ripping out wires here is what I was getting with a multi-meter:
Field (s/g)- Field term - 0 ohms
Field (s/g) - G term- 0 ohms
A (s/g) - G term - 0 ohms
A (s/g) - Field (term) - 0 ohms
12.5 volts (battery static charge)
0 ohms - Batt Neg Terminal & foot ground (v/r)
Voltage @ G terminal (used battery ground) - 2.5
Seeing as I was essentially having all wires connected I have decided to just start fresh - it is a rat's nest of wires under the dash.
One question - is there any way that a stuck point in the v/r could cause all points to show continuity?
Any tips / tricks on rewiring is greatly appreciated - PICS soon to follow.
Old 04-15-2014, 07:21 AM
snoel's Avatar
snoel snoel is offline
Default Mine too
My (new to me) 149, also needs rewiring. Engine was upgraded to newer design, with gear starter. No voltage from stater, and other wire messes. Tractor runs great, but will have to charge the battery from time to time. So will eventually tear it out and start over. Winter project?
Steve
Old 04-15-2014, 10:32 AM
Trekrider60's Avatar
Trekrider60 Trekrider60 is offline
I also have a new-to-me 149. I got it in Jan. My wiring was all painted yellow from a paint job. I labeled each wire end as I removed the connection. My local Electrical/Plumbing supply had 8 different colors of 12ga stranded wire. I followed the wiring diagram for the color of each wire. There are a few wires that are different, but I recolored a wiring diagram with the colors I used. My light wires are now white instead of violet as an example. I bought 6ft of each color wire ($0.17/ft), four boxes of end connectors ($1.99/box), and 10ft of plastic wire conduit ($4.95). I have less than $25.00 in the new harness. I haven't tried it out yet since the 149 is torn apart ready to be sanded for painting. Good luck with your 149.
Old 04-15-2014, 10:38 AM
snoel and trek: thanks for the info. That shopping list sounds pretty good and will save me some time trying to dream up my own - thanks for sharing.
