Old 10-24-2018, 12:26 PM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Default Farmall light switch in a cub
So, I'm planning on putting a 3 position switch in my 1250, would a switch from a farmall 560 work? Isn't it Low beams, High beams, and rear light? I would like to put a front and rear worklight in and wire it up to not always be on.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 10-24-2018, 12:59 PM
Any switch will work if wired properly.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 10-24-2018, 01:01 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Are you trying to hook up lights other than headlights/taillights? Otherwise, just a simple on-off switch will do.
Plow blade
#2 Cart
QA36 snowthower
Old 10-24-2018, 01:05 PM
Leadslingingdaddy's Avatar
Are you looking to have it do Front, Back, Both, and off???
Old 10-24-2018, 01:07 PM
I believe he wants one of these, it is 4 position by the way...
Up to 534 and counting...
Old 10-24-2018, 01:28 PM
Mudrig150's Avatar
I want low beams, high beams, and worklights. I want either a 3 or 4 postion switch, if I can't find anything I'll just go with an Off-onA-onB switch.
Old 10-24-2018, 01:35 PM
you can try ebay/ Steiner tractor, part number is 371465R91
Old 10-24-2018, 01:52 PM
cooperino's Avatar
Honestly I would keep head lights and "work lights" on separate switches. One on/off for work lights one on/off/on for high beam and low beam head lights
Old 10-24-2018, 05:20 PM
Just an observation, you seem to be into more projects than I can count.
(https://www.onlycubcadets.net/forum/...archid=1117007)
May I suggest that you finish one project before starting another.
Old 10-24-2018, 05:22 PM
IMHO....I would agree.
