Old 10-28-2018, 08:44 AM
danman danman is offline
Default 2182 hydrostatic tranny part number /swap
First cub cadet. 2182 with the kubota gas. wanted to identify the tranny part number and find a spare
e.g. what other models share same tranny?
thanks for any info
Old 10-28-2018, 08:50 AM
cooperino's Avatar
First.. Welcome to OCC!
Is there an issue with your trans?
Old 10-28-2018, 08:52 AM
Welcome to OCC!
I am not familiar with your model.
But if you go to cub parts look up, and type in your model, then go to that part, and see what all that part fits, it should give you an idea what you are looking for.
AND you will learn how to do that for another time/question in the future.
This was discussed just this week here.
Old 10-28-2018, 08:58 AM
First, welcome to OCC ----------->
The 2182 had three production ranges. I don't know where your tractor fits in.
The 2182 utilized the Sundstrand Hydro ----> Sauer-Danfoss 15U Series type of pump. Specifically, CC #717-3312.
These pumps have an excellent track record. It is seldom to see failure unless it is damaged.
Although 15U Sundstrand Pumps were widely used in the L&G Industry, one would need a Cub Cadet Specific pump for proper replacement.
Old 10-28-2018, 09:33 AM
Thanks for replies!
Tractor performs OK As Is Prior owner changed filter and fluid
Reverse is really SLOOOW.........
Found a 2086 locally i thought might be a good backup tractor ;-)
Was hoping the trannys might be a identical swap
BTW I assume ground speed also relates to engine rpm?
Old 10-28-2018, 09:34 AM
cooperino's Avatar
Originally Posted by danman View Post
Thanks for replies!
If reverse is slow. Check over all your linkages and make sure theres no "sloppy" bushings and pins.
Yes. engine speed will determine speed and response of hydro.
Old 10-28-2018, 10:13 AM
Slow reverse was a common problem, this is the Cub service bulletin about that issue.
Old 10-28-2018, 02:10 PM
Thanks SAM MAC I will check it out ...
Back to the original question does 2086 have same tranny as the 2812?
Old 10-28-2018, 02:34 PM
All of the Cyclops Supers would have an interchangeable trans and pump
Cyclops
1782 Kubota D 640 diesel
1882 Kohler Mag18
2086 Kawasaki FD620D
2082 Kohler Mag 20
2182 Kubota WG-600 gas
2084 Kohler CH20
2284 Kohler CH22
Older Supers will also work but the axles are different.
982 Onan
984 Onan
986 Onan
1572 Kubota D 600 diesel
1772 Kubota D 640 diesel
1872 Kohler Mag18
1912 Onan
1914 Onan
2072 Onan (early 2072's had Onan's)
2072 Kohler Mag 20
