Old 11-10-2018, 08:54 PM
john hall's Avatar
Default Those plastic grills
About a year or so ago I put a new grill in my 2284. Doubt I have ran it over 10 hours since. Today I was tightening up the 2 bolts that stabilize the front axle and noticed one side has a crack under the bottom. Haven't ran into anything, nor do I think anything has ran into it under the shed. Wondering if I overtightened the grill when I installed it, or if its just a bad design. I don't remember any bad flashing that would have caused it to bolt down with excessive pressure, but can't swear to it.
Anyone else ever had this to happen or have an idea how to deal with it? I'm thinking that I will use some of the plastic welding type glue on it. Don't know if there is any way to reinforce it or not. Wonder if there is any product that I could use to "bed" the grill in place with? Thought about neoprene or using JB Weld to create a "nest" for it to sit in. Thought, ideas, suggestions?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-10-2018, 10:57 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
I doubt it's anything you did. They all break eventually. Most sooner than later.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 11-11-2018, 04:50 PM
If the "grille" cracked in the center, under the opening, I suspect you slid the grille too far back on the frame and the grille bottomed out on the frame and cracked it. Don't know. Just an educated guess.
Since that thread, I've bought other tractors that have no plastic damage that are 25+ years old. You just can't ram them in to things or ham fist the plastic when you move the panels.
Old 11-11-2018, 09:55 PM
V30crewcab V30crewcab is offline
I'm guessing you have the factory metal plate with the two nuts welded on it in there? I have one I need to buy a grille for. really wish I new more about casting, I'd try to cast one in aluminum!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 11-11-2018, 10:03 PM
sorner's Avatar
sorner sorner is offline
The plastic is pretty much why I decided I like the 82 series better.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 11-12-2018, 06:11 AM
bugeye bugeye is offline
I think the grills crack due to age and heat even if no impact. I have repaired with sections of PVC from electrical boxes. Unfortunately, the PVC is also affected by the heat.
Would fiberglass tolerate the heat and vibration? Could a form be made to duplicate in fiberglass?
1863, 1864, 48" and 54" mower decks, 54" snow plow, 451 snow blower, TracVac 580
