Old 11-18-2018, 04:24 PM
RAC65 RAC65 is offline
Default IHC cast hydro into 1864?
Hey guys, new to the site but not necessarily new to cub cadet tractors. This might be on the site somewhere but I've been unable to find. How many issues will I run into swapping a 169 hydro transaxle into an 1864? I have a 169 that I've had for years and an 1864 that I gave $200 for on Craigs List last summer (supposedly non-running). Turned out all the 1864 needed was a head gasket and ignition switch.
Many years back I built a cat O 3-point with a 3X6 inch lift cyl. for the 169 that bolts on as a unit in place of the rear trans cover. I'd like to thin the herd a little and the 1864 runs smoother, is quieter, has more power and power steering. But I don't believe the aluminum transaxle in the 1864 is up to the task of handling my 3-point hitch tiller (36 inch FMC w/ its own 18 hp engine). I'd estimate the tiller to weigh +/- 400 lbs. I have to put about 240 lbs ballast on the front of the 169 when its mounted to make it manageable.
Will the charge pump in the 169 handle the power steering in the1864 chassis? Not too worried about driveshaft, have access to mill and lathe, can make anything. Linkage issues??? (haven't taken covers off to compare side by side)
Thoughts???
Old 11-18-2018, 05:24 PM
IHCubCadet147's Avatar
IHCubCadet147 IHCubCadet147 is online now
I don't know if it will fit or not, but you might not want to part out a 169 since they are a rare model.
Old 11-18-2018, 05:45 PM
CubDieselFan's Avatar
The aluminum rears with rear braces would handle the stress. There are plenty of cast rears out there without parting a 169. Just sell it and buy your parts.
Old 11-18-2018, 07:21 PM
Welcome to OCC....
Old 11-18-2018, 08:39 PM
The 169 is no beauty queen, can't honestly remember how I ended up with it. been 20 years or more. I know it had no engine at the time and the one I have in it is made up of old left over pulling motor parts (billet rod, forged pop-up piston/mated head and some other odds and ends that were laying around).
So you think that 1864 rear would handle the weight? I mean really, with 240 extra lbs clear out on the front of the tractor it just barely keeps the front on the ground. This tiller is REALLY heavy.
Old 11-18-2018, 08:56 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
The aluminum rear has a stronger carrier and axle shafts.... put a set of the Xtreem Motorworks braces on the 1864 and you will have no problems.. way easier than swapping rears.. Don't be scared of the aluminum rears.. they are OK once you brace them back to the frame
Jay
Proud owner of the following:
Old 11-18-2018, 10:20 PM
DeltaCub's Avatar
DeltaCub DeltaCub is online now
X 2!!!!!
Queen Of The Quietlines!
Old 11-19-2018, 05:49 AM
twoton twoton is offline
Hey RAC65, how 'bout some pictures of that cat 0 you built.....
Old 11-19-2018, 06:55 AM
You can swap a cast rear into the 1864, you'll need to use the pump from the 1864 because it has the splined input shaft and the pump on the 169 has the spirol pin type shaft. Just my 2 cents, as others have said put a set of Xtreme rear end braces on it and a 3 point hitch and be happy. I have a nice used Xtreme 3 point for sale that will fit the 1864. $300 plus shipping. PM me if you are interested.
Old 11-19-2018, 09:40 AM
sorner's Avatar
sorner sorner is offline
I put a cast rear into a 2284 but only because the aluminum was destroyed. That was a little more difficult than putting it in an 1864 because I had to also swap the reduction gear. For the 1864, swapping the pump and installing a new cork gasket should be about it.
There have been intense opinionated debates on here about this very subject, it's a matter of opinions as to which is better and why. Just like what oil to use in the rear. The cast iron is heavier than the aluminum, but I've learned that unless the rear is broken and you already have the parts, it's not really worth it to do that swap, when wheel weights and/or loading the tires will add weight just the same.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
