Old 11-20-2018, 07:47 PM
Mike Winterbotham Mike Winterbotham is offline
Default Stock Engine for pulling
Who builds good stock pulling engines i have all the parts just needs put together
Old 11-20-2018, 08:02 PM
cooperino's Avatar
First off welcome!
When you say you have all the parts. You mean new parts I am assuming. Have you had all the machining work done already? For a nominal fee most machine shops doing machine work will also assemble.
Old 11-20-2018, 08:19 PM
No i havent done any machining done but i have all new parts to rebuild it i live in Ohio looking somebody to sit it up for pulling
Old 11-20-2018, 08:27 PM
cooperino's Avatar
Well. Before you "set it up" you need to get it to a machine shop. You can't just put new parts in a used block with out machining. Bring your parts to a reputable machine shop. Let them do all the machining and put it together if your not able to do yourself.
Old 11-20-2018, 09:30 PM
Merk Merk is offline
Welcome !!!!
What part of Ohio are you from?
Sent you a PM
Project Uncle Dick
Cub Cadet 70
Old 11-20-2018, 09:41 PM
john hall's Avatar
Yep, if you don't have the correct tools, let the machine shop build it.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-21-2018, 02:50 PM
what would be a good carb for a K341 stock for pulling
Old 11-21-2018, 04:10 PM
dodge trucker dodge trucker is offline
You say stock. That is where I would start, but get a Carter/Kohler version not a walbro. Either was stock thru the years
Old 11-21-2018, 05:18 PM
I rebuild engines. They are mild puller engines to stock replacement for daily use Cub Cadet(s).
I would look at the class rules before buying a carb or a rebuild kit for your puller. There are plenty of things that could be done...some legal-some not legal.
Project Uncle Dick
Cub Cadet 70
