Old 11-24-2018, 09:43 AM
RT0426 RT0426 is offline
Question QA36A Snowthrower Bearings
I have recently obtained a QA36A snow thrower for my Cub 129. However I need to replace the auger bearings. I have the bearings but am stumped as to how to loosen the auger enough to be able to slide it out of the housing. Any tips ?
Old 11-24-2018, 11:34 PM
Gompers Gompers is offline
I'll assume you have the bearing holders loosened up.
There's a locking collar on the bearings. You'll need to loosen that up. Theoretically the auger will slide on a bearing a bit, and you can move it one way and free the other end up far enough to get it out. Reality is that they never seem to move, and it's a struggle. You might find yourself with a big pry bar bending the housing a little to get enough room to wiggle one out, or beating the auger shaft from the outside to try to get it to move.
It's not a delicate operation.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 11-25-2018, 09:21 AM
Default Rt0426
That worked after I got the collars loose it did not take much to pry the auger out of the housing. I just did not want to force anything if I was not supposed to. Thanks for the advice !
Old 11-25-2018, 12:24 PM
Excellent. I had my QA36B apart last year, and the bearings were pretty well seized to the shaft. Not a lot of fun. Took some emory cloth to them before I put it back together, and re-assembly was a lot better than disassembly.
