Old 12-11-2018, 08:19 AM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Default Destroyed exhaust threads
I'm trading the 1250 for a nicer 1250. He wants my 1250 to come with everything, including the muffler parts. I don't know what to do with the elbow, as the threads in the block are f***ed beyond repair. They're so wallered out from the old exhaust, that the elbow only has about 3 lines of threads to grab onto. How would I go about fixing it?
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 12-11-2018, 09:11 AM
cooperino's Avatar
If they are that destroyed and there is no saving them.. Jam it in and weld it
Old 12-11-2018, 09:26 AM
A picture is worth a thousand words. Let us see exactly what you are talking about.
Old 12-11-2018, 10:16 AM
Mudrig150's Avatar
I apparently don't have any, but it looks like someone stuck a larger pipe in the hole and really torqued it in, the threads are about a cm larger around the end.
Old 12-11-2018, 10:18 AM
Get a tap and clean them out and maybe add a few more on the inner surface.
I have salvaged several that way.
It's just a pipe thread.
Have you got the elbow/pipe out of it?
Old 12-11-2018, 10:51 AM
I have cleaned up a few exhaust ports, but the procedure may not be applicable to yours. Can't tell, NO pictures.
Old 12-11-2018, 11:27 AM
twoton twoton is offline
Some of the blocks came with holes already drilled and taped for stud mounted exhaust flange. See post #184 in my thread ''What a rag' for a picture. If you have this on your block, Fab your own exhaust like the pullers do.
Old 12-11-2018, 12:11 PM
Mudrig150's Avatar
I do have the elbow but it feels a bit loose in the hole even when fully screwed in. I don't have a muffler right now to test if it seals but it seems to seal with the old muffler screwed in.
The elbow came off another 1250 and the whole thing was a rust bucket, almost every bolt was broke in one way or another, so there is really no way to tell how hard it was to get out.
If it was anything like the k321 motor we have it's probably close to snapping off in the block.
Old 12-11-2018, 01:53 PM
Well....I wish you luck.
Old 12-11-2018, 01:59 PM
Mudrig150's Avatar
Yeah. I'll need it for when I eventually have to remove the snapped elbow out of the k321 block.
