Old 12-15-2018, 12:07 PM
AL Farmall Boy AL Farmall Boy is offline
Default How do you guys Work on Engines Out of the Tractor??
Just curious how You guys work on the Koehler engines when they have been removed from the tractor. I am wanting to do as much as I can to the engine.....replace worn and broken parts, tune up parts, and disassemble for paint. I have a work table to sit it on but I feel like it will just be a heavy brink rolling around on the table.
Old 12-15-2018, 01:06 PM
IHinIN IHinIN is offline
I built an engine stand that bolts to my work bench. It has a 1” diameter stub welded to a plate that bolts to the block where the starter attaches. It slides into a tube on the bench. It pivots and locks in place every 90 degrees.
File Type: jpg B2598500-1B62-4968-A3B2-06DA33AB0F45.jpg (23.8 KB, 246 views)
Old 12-15-2018, 06:50 PM
dodge trucker dodge trucker is offline
Some time you have no choice but to work on them rolling around on the bench. Depends on what all you are trying to do to the engine. I have rebuilt more than a few that way, not a big deal especially as the parts start coming off
Old 12-15-2018, 10:09 PM
john hall's Avatar
Toss it up on a sufficient work bench and go at it.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-15-2018, 11:21 PM
Looks good!! Yeah I’m planning on disassembling and painting it piece by piece with the main engine intact. Painting the tins and other parts separate. Also going to remove and clean head and replace head gasket amongst the typical tube up stuff. I just wanted to know how you all did it because I figured you’d have a good useful way to get it done without it sitting loosely on a table. That is a good idea to build a rotating stand to bolt to the work bench.
Old 12-20-2018, 04:10 AM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
I bought a wooden bar stool and set the engine on that.
for when I'm working on a vertical shaft motor I drilled a 2" hole in the center of it.
I recently bought a tool cart from HFT that I'm going to put a piece of plywood to the top and use for an engine stand
I mostly am doing this to make it easier to move around (wheels) and the cart is 2'x3' where the stool is only about 18" circle.
I put the top tray on upside down so I wont be working in a hole
JD x475
Old 12-20-2018, 07:18 AM
Leadslingingdaddy's Avatar
With my hands... of course
Old 12-21-2018, 06:53 PM
Hober43 Hober43 is offline
Job crane that I got from work they were throwing away. No pictures of a motor hanging but had one of a parts tractor322DFFA3-9CA4-4999-9A26-E732EEB8A605.jpg
