I'm looking at a 104 to possibly purchase for a plow tractor, but the one I'm looking at, the owner says it breaks a clutch teaser spring every year. He still uses it weekly to mow grass, but what would cause it to break a teaser spring every year? Think it could be assembled wrong?
Proud Owner of These Fine Cubs 1961 Cub Cadet Original - 1966 Cub Cadet 102 - 1967 Cub Cadet 104 w/ hydraulic lift |
Assembled wrong,worn driveshaft,misalignment issue, I haven't done one lately but if assembled correctly with the right parts it should not break !
That's sort if what I thought, I've never put one in, but I believe i saw in another thread that the way it is shown in the parts diagram is wrong?
Is this throw out bearing a Cub Cadet version or a cheap aftermarket version?
The after market throw out bearing is thicker than the Cub Cadet version.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
I think my 108 had a hatefully worn/grooved/taper on it where the throw-out bearing slides and after replacing the driveshaft things aligned better and clutch worked much smoother without breaking the teaser spring ! |
I've never worked on a cub cadet clutch before so this could be a learning experience!!
https://www.onlycubcadets.net/forum/...l+transmission
