Old 01-12-2019, 05:02 PM
AL Farmall Boy AL Farmall Boy is offline
Default 1450 Cracked Aluminum Muffler Support
I wanted to know how imperative it is to either fix or replace this aluminum piece if it is cracked. I don’t have a good used one, but I did purchase a steel muffler brace that is supposed to keep this from happening.
What do you guys do to repair these, or should I just replace it? If I was to install that brace, could I just leave this cracked one on?
Old 01-12-2019, 05:06 PM
Pictures of the cracks
File Type: jpg 2A0DCE4F-298B-47B7-B48B-C89396E902B5.jpg (23.2 KB, 120 views)
File Type: jpg D8AA559B-2995-45C9-8ED6-4BFDF9940961.jpg (20.8 KB, 122 views)
Old 01-12-2019, 05:32 PM
twoton twoton is offline
Fix it if you want, it will prolly crack again. In your second picture, that bolt. I removed mine and drilled a through hole, added the muffler crutch, added a backing plate (on the coil side) and then through bolted it all.
Old 01-12-2019, 06:19 PM
How would you fix it? I was thinking of drilling 2 small holes at each end of the cracks, grooving them out a little with a dremel, and then filling all cracks and holes with jb weld.
Old 01-12-2019, 08:17 PM
Find someone who can weld it for you. You can also have them weld a backup plate where that top bolt is.
Old 01-12-2019, 08:43 PM
finding someone that will weld aluminum around here hasn't proved to be easy or reasonable. I've got something else I wanted welded.
Old 01-13-2019, 02:21 PM
GeneW GeneW is offline
The tin on my 1450 had been welded years ago and the aluminum air duct was cracked at most of the welds when I took it apart in 2018. I fabricated some small angle iron reinforcement for the areas that needed a threaded hole and used rivets to hold the new angle iron in place on the air duct. Used sheet metal patches and rivets to bridge some of the other cracks. I think installing a muffler support bracket will help quite a bit. It's not pretty, but it is holding together.
