Old 01-20-2019, 02:07 PM
sorner's Avatar
sorner sorner is offline
Default 551 blower lift rod help
While blowing snow this morning, more like slush, I had a clog so I lifted the blower to clear the clog and my lift rod that goes from the lift arm to the blower turned into a U and knocked the side panel off the hood from the extra weight of the jam of slush and snow. I was able to get it off and heat it with a torch, and hammer bend it back relatively the way it was and I almost got finished and it bent again. Clearly it’s weakened now. I’m thinking I might have one made. Is it anything special metal wise? I seems hollow. It also seems like it should have some reinforcement at the factory bend. Because that’s where it kinked.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 01-20-2019, 02:28 PM
All the Lift Rods I ever seen have been 1/2" Round Solid Steel.
Old 01-20-2019, 02:37 PM
sorner's Avatar
This is way bigger than 1/2”. It’s 1” thick. I doubt I bent 1” solid steel
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 01-20-2019, 03:13 PM
It "looks" like 1" tubing. I would agree, it looks weakened.
Old 01-20-2019, 03:29 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Think a push rod made from square stock or tubing would fare better than round myself
1- 1200 in pieces
1- 1864 in pieces
Old 01-20-2019, 03:33 PM
Gompers Gompers is offline
I bent mine yesterday too from trying to use it when the linkage was over-center. Lesson learned for the future. I hear it's a fairly common problem. The lift mechanism for these isn't the best, IMO. Be grateful it was that lift rod and not your rockshaft.
I just bent the tip of mine, so I'm thinking about machining a little "sleeve" to go around the tip and re-enforce it to see if I can keep it from bending there again.
They are still available from MTD. I don't think they would be too hard to make though.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 01-20-2019, 04:34 PM
John147 John147 is offline
If someone starts making a heavy duty one i might be interested in one as i see this happening to mine as well lol.
Old 01-20-2019, 06:11 PM
cheesedawg82's Avatar
cheesedawg82 cheesedawg82 is offline
I made 2 of these yesterday for my plows. I welded nuts to either end of an appropriately sized length of conduit, took 1/2" × 8" "L" or anchor bolts, drilled them for cotter pins, tacked on washers, and added a spring assist for the 106.
There's slop in the threads. They're the weak point in the design, and if it fails it will be the thread in the nut. If someone with a lathe would drill and tap a couple inches of thread into either end of a heavy rod or appropriate sized tube, it would be quite beefy. Reverse threading one end would make adjustability that much easier.
We got 3/4 of an inch of snow last night and I plowed my whole block in 3rd gear without breaking anything.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
Old 01-20-2019, 09:21 PM
dale c. dale c. is offline
weld a piece of angle iron onto the side of it to reinforce it
Old 01-20-2019, 11:18 PM
Originally Posted by cheesedawg82 View Post
I made 2 of these yesterday for my plows. I welded nuts to either end of an appropriately sized length of conduit, took 1/2" × 7" L bolts, drilled them for cotter pins, tacked on washers, and added a spring assist for the 106.
It looks like it works well for that application, but it's a whole different system. That rod lifts when it's in tension. The rod on a 450/451/551 lifts in compression.
