Hi guys,
My Cub 2284 is a great tractor and I love these Supers/Cyclops tractors. Mine has a 60" Haban deck that I mow with and sometimes it seems like the engine doesn't have as much power as my 2072 when running the same 60" Haban deck. I thought, since I have a brand new Kohler CH23 (which has quite a bit more displacement than the CH22), I'd swap it in my 2284. Well it's not that easy because of one big problem. The CH23 has a 1-1/8" shaft and the CH22 has a 1" shaft. Please give me your advice as to what direction I should go on this. If I put the CH23 in, along with a GT2550 electric PTO (that I have sitting around) to fit the 1-1/8" shaft, will everything be fine? The pulleys on the electric PTO shaft for both tractors is 6" in diameter, so I should be fine in that respect. I'm pretty sure that the clutches are slightly different, but I don't know if this swap would work or not, but if you guys could give me some pointers, I'd really appreciate it. Thanks in advance! |
First, I am going to say that I have never done the swap you are talking about,
If this were me, my focus would be on the PTO geometry and alignment, IF..... front driven implements are going to be used. That would be a big factor. How you modify and alter the drive line, linkages, electrical, mounting, and etc, is less critical...in my opinion.
Thanks guys! And Sam, I actually didn't measure the shaft size on my CH22 yet. I was just reading about your Kohler Command swap in your 1882 and I noticed you got an engine with a 1" shaft. I thought you used a 1" shaft engine because the electric PTO was a 1" size. It looks like all of my worrying was for nothing, because the electric PTO shaft size is 1-1/8" on my 2284, so this will be a simple bolt on and go swap. Thanks again!
OK but pay attention to the wiring, the SAM engines have 12 volts going to the SAM box and you need to make sure you don't hook that up to the Mags on the CH23 or you'll be buying 2 new mags.
This is how the 2284 was wired from the factory. You should see a red wire on the original engine that goes to the SAM box, after looking at the diagram pretty sure you can just plug it the factory harness to the new engine but I suggest that you take some time and check first with a meter. It was 2012 I did the CH swap on the 2284.
I never even knew about the SAM, spark advance module on these engines. This forum is a wealth of knowledge and this is a HUGE help. Thank you, Sam! I'm going to take a look at my newer replacement CH23 Kohler and see if it has a SAM box. It's a relatively newer engine that I bought brand new from a store on ebay selling them off back in 2011 or 2012 and it actually says Cub Cadet on the air filter cover.
How can I tell if it has the SAM box? Also, the attachment you uploaded showed up too small......when you get a spare minute or two (no rush at all), could you PM it to me? Again, thank you very much for all your assistance! |
SAM box is on the right side of the engine as you sit on the tractor on the blower housing
I e-mailed the diagram to you.
Thanks for pointing that out. I never noticed the SAM box on the Kohler engines before. If the CH22 in the Cub has it, I could probably just swap the SAM box components over to the CH23 engine that I'm swapping in and everything would be a simple plug and play swap.
