Old 07-22-2010, 02:11 AM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
Default Need to load your tires for winter?
Menards has a sale on windshield washer fluid for $.68 a gallon. There is a limit of 12 so take those out to the truck and go back in for more. Maybe take the wife? I think it will take 7-8 gallons to fill one 23x10.5x12.http://www.menards.com/weeklyAd.do
Old 07-22-2010, 02:55 AM
Great find!
Old 07-22-2010, 06:02 AM
nikster's Avatar
nikster nikster is offline
I always stock up when I see it for sale. I've bought them for as little as .99cents a gallon. Seems that the anti-freeze stuff in the last 2 years has started to become exploited & i've seem it as high as $1.69 to $1.99 a gallon.
Heck I can stack away 15 gal., of the stuff with NO PROBLEM.
Nice find,
Nik
+ 32deg. No Good! Well not for Winter that is.
Old 07-22-2010, 07:47 AM
jmildoc jmildoc is offline
how do you pump it into your tires?
Old 07-22-2010, 08:02 AM
dross dross is offline
Default tires
Tire bong, I lost mine in a move. Ot was a 4 ft loong PVC pipe with a cap on the bottom I drilled and taped to hook up a fitting for the hose (I used a hose off a can of fix a flat so I could screw it on the valve stem) On the top I used a clean out fitting to fill it with fluid. and a steel valve stem toward the top to hook my locking tire chuck to. Used the smallest setting on the regulator off the air compressor. Hook up the tire, fill the bong hook up the air and pump the fluid in. gotta let it burp a few times.
Old 07-22-2010, 12:47 PM
Here's a thread to help with the filling procedure. http://www.onlycubcadets.net/forum/s...ead.php?t=1343
Old 07-22-2010, 01:49 PM
ihnick's Avatar
ihnick ihnick is offline
i use a hand pump garden sprayer put drilled a hole on top and put a valve stem in. so all you do is fill up the sprayer, slide the hose on the tractor valve stem, then blast the sprayer valve stem with the air hose.
Nick.
Old 07-22-2010, 01:59 PM
gcbailey's Avatar
gcbailey gcbailey is offline
anyone ever used one of those small rotary pumps that goes on a cordless drill? Harbor Freight has them for around $12 all the time. When I filled my All Trails using "gravity" it took about 2.5 hours, long hours.....
Gary
Old 07-22-2010, 04:28 PM
ihnick's Avatar
It took about 10 minutes to put 6 gallons in my tru powers with my sprayer mentioned above
Nick.
