Old 03-22-2019, 06:10 PM
athomas's Avatar
athomas athomas is offline
Default 125 cobbling
Started checking out my latest purchased 125,thought I'd share some of the previous owners handi work ! Weld repair and additional set collar on the back of the basket pulley, fine looking crankshaft fit for the pto & I've never seen a pto assembled that way ? Told me he hadn't had the deck on it for 10 years or so, wonder why ? Still a nice 125 for the price ,just a little extra work needed!
Old 03-22-2019, 06:22 PM
twoton twoton is offline
Them thar looks like some high quality welds there.
Old 03-22-2019, 06:29 PM
Turn the crank *90 and mill a new keyway, add a replacement clutch and all is good
Old 03-22-2019, 07:03 PM
athomas's Avatar
pic doesn't show it but crank is ground down way undersized, looks like they took a grinding wheel to it ! Cheaper to find another crank than repair this one.
Old 03-22-2019, 08:58 PM
cooperino's Avatar
Can ya make up a bushing on a lathe? If the engine runs well I think I would go that route.
Old 03-22-2019, 09:41 PM
athomas's Avatar
Can't make a bushing,no lathe, still would need to cut crank and true up to some uniform size to make bushing fit ? Would need to pull crank to have new keyway cut,work either way I suppose, I have a spare engine and likely will make one good one out of the two ! This one runs good, no smoke but has an internal problem with the gov so I need to open it up to fix that issue, reset gov a couple times to be sure,must be a broken gov or weight off or something , no resistance on the gov arm when running ,looked at everything external I could think off so I'll get the spare up and running ( not sure of it's condition ) or fix this one !
Old 03-23-2019, 12:22 AM
johncub7172's Avatar
True the crank up just start the engine and hold a flat file to it👍🏻 Then try a bushing. I make a lot of stuff on a poor mans lathe lol! Let’s see some Picts of the 125 when ya can!
Old 03-23-2019, 07:55 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Finally, someone who welds as poorly as I do!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 03-23-2019, 08:04 AM
The file method will not produce anything remotely near true, especially bouncing on the keyway flat every revolution.
Swap cranks or look on the internet sites like evil pray for a good used one.
I've done some shady repairs in a pinch to keep equipment going, but there is a limit, no offence to anyone.
Old 03-23-2019, 09:05 AM
athomas's Avatar
I've Macgyvered some things myself to get by , but this crank would need welded up and remachined to be right,easier and less costly to replace !This tractor was purchased to flip so I need to make it right before selling ! don't want someone to else to inherit this mess !
