Old 03-27-2019, 08:40 AM
AL Farmall Boy AL Farmall Boy is offline
Default Semi-Gloss Black Paint Source?
Does anyone know where I can get Semi-Gloss Black Enamel Paint to paint the Cub Cadet trim pieces, and Kohler Engine? I've tried Case/IH and they just offer a Gloss Black. The automotive paint stores say they don't have a semi-gloss, but one PPG store had a satin that was similar, but he wanted $304.00 a gallon for it. I need about a quart, and am not paying that much for it.
Old 03-27-2019, 08:50 AM
I use Krylon.
Old 03-27-2019, 08:54 AM
I use Krylon.
I'm not wanting to use rattle can at this point but might be forced to. Do you have pictures of your painted stuff?
Old 03-27-2019, 09:10 AM
Smjohnson Smjohnson is offline
Default Black-Semi-Gloss
https://www.lowes.com/pd/Rust-Oleum-...-fl-oz/4459357
Old 03-27-2019, 09:27 AM
You can buy Krylon by the Quart or Gallon.
Old 03-27-2019, 11:43 AM
Hmm.....funny I went to lowes looking for that exact stuff and they only had gloss and flat black.
Would you say the Krylon or the Rustoleum is better? I know the Krylon rattlecan primer is really thin stuff going on. Of course I will be mixing this paint with some Acrylic Enamel Hardener and reducing it as needed with enamel reducer to spray through my HVLP gun.
Old 03-27-2019, 12:34 PM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
It's hard to believe a quality automotive paint supplier can't mix it. It's as simple as adding the correct amount of flattening agent to gloss black. I'd suggest trying a different supplier before giving up.
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 03-27-2019, 01:50 PM
ironman's Avatar
ironman ironman is offline
I like Rustoleum Satin Black. It seems to have less sheen than semi-gkoss but more than flat.
https://www.amazon.com/Rust-Oleum-77...gateway&sr=8-5
Pics ere taken in bright sun...
I prefer Krylon over Rustoleum for only one reason. Krylon seems to dry faster.
Old 03-27-2019, 05:56 PM
ironman's Avatar
I totally agree about Rustoleum taking an elephants lifetime to dry when used straight out of the can or rattle can. But when thinned, hardener added, and gun sprayed, I think drying time improves quite a bit.
