Old 03-27-2019, 09:04 PM
JRoberts JRoberts is offline
Default 149 Hydraulic Leak
I have a leak on both of the metal hydroaulic lines coming out of the pump. The inside part of the flare is loose. I’m assuming that’s what pushes to make it right as the nut goes on. Wasn’t sure of the leak is coming behind that piece and it should be welded or brazed to the metal line . I have attached a couple photos.
File Type: jpg 2BD66F7B-9C71-4CE4-957A-A68EAEFA48A1.jpg (19.2 KB, 57 views)
