Old 04-04-2019, 05:18 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Default Spirol pin for Steering Arm
For the Cub Cadet 125, I need to replace the 5/16 x 2 spirol pin...... And McMaster-Carr has several choices! Does it matter and is one better than any of the other? There is steel, heavy duty steel, Stainless Steel and even HD stainless steel. Thanks in advance.
Plow blade
#2 Cart
QA36 snowthower
Old 04-04-2019, 06:02 PM
I would go get the reg. steel one.
Old 04-06-2019, 11:39 AM
AndrewNoyes AndrewNoyes is offline
Just remember Spirol or coil, not just a roll pin.
Old 04-18-2019, 01:27 PM
dodge trucker dodge trucker is offline
No it don't matter, those things all suck to remove later
Old 04-18-2019, 09:37 PM
Billy-O's Avatar
The BFH got the old one out in less than a minute..... ......but I wouldn't try that on the drive components with out first supporting the shaft. Either the BFH or I was just lucky
Plow blade
#2 Cart
QA36 snowthower
Old 04-18-2019, 10:24 PM
I just took a few parts off of a 1650 and the BFH needed help from an air powered 3" cutoff wheel, and the smoke wrench to get the spirol pins that I removed, out.
