Old 07-24-2010, 07:08 PM
Lmercer Lmercer is offline
Default 1650 Pump to Transmission Gasket
I need to replace the gasket between the pump and transmission on my 1650. Do I need to remove the unit from the frame and tip it up to do it? I have an engine hoist and I wasn't sure if I could just lift the front end as high as I could.
Old 07-24-2010, 07:28 PM
Lmercer
I have always rolled the rear end out and tipped it up. Just seems easier to me. Few more things to unhook, but so much nicer when you start putting the hydro unit back on the rear.
Old 07-24-2010, 07:30 PM
cub149's Avatar
cub149 cub149 is offline
I just did mine a while back. I pulled the rearend out to do it. It's a tight fit trying to get to the bolts inside the frame with the rearend in. I put jack stands under the frame and used a floor jack to hold the rearend in place while it was unbolted, then just rolled it out from the tractor. It is easier to clean and get to everything this way but others just leave it in. I'm sure there will be others with ideas but to me this was the easiest way.
Chip T.
Drexel NC
