Old 04-12-2019, 03:01 PM
Cubcadetman94 Cubcadetman94 is offline
Default 105 PTO problem
Hello everyone, new to the forum so I figured best time as ever for a welcomeing question. I have a 105 with the missing PTO thrust button, I know I've seen them for sale on eBay and a few sellers here and there. Is there a temporary fix I can use until I purchase one? Only need it for one mowing. Thanks everyone!
Old 04-12-2019, 04:46 PM
cubs-n-bxrs's Avatar
There is really no quick fix's for that situation. The clutch will have to be removed to fix it correctly. Welcome to the OCC. What part of NY do you reside?
Old 04-12-2019, 09:55 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Welcome to the forum! I doubt there's a quick fix other than doing it right! If you need the thrust button that goes into the swing arm shaft, Jeff in PA makes 'em cheap and gets it to you quick as he can. Check this link: https://www.onlycubcadets.net/forum/...ead.php?t=2087 You do not need to remove the PTO to replace the missing thrust button on the swing arm. However, if the other button on the PTO pulley is missing, you might have to consider rebuilding the PTO or replace it.
Plow blade
#2 Cart
QA36 snowthower
