Old 04-18-2019, 07:32 AM
Exlr82fast Exlr82fast is offline
Default Pincor generator
New here...anyone have any knowledge with a pincor generator that mount on front of a cub? Mine isn't working got it apart was told by a guy at work that the rectifer may be bad? He said when you dont use a generator for a long time they lose change. I'm not sure of this. If that could be the problem where in the world can a person find one? It's easy to to get to as if it is a part that needs replaced or serviced. It's a plate right on the front of the gen. Any help would be great... manual would be awesome
Old 04-18-2019, 07:58 AM
Seen a few pincor's over the years, but never worked on one.
As far as a generator sitting and loosing it's field excitation, yes it is no myth, it does happen.
Some generators don't have that problem, others do.
Some are as simple as a quick spark from a 6 volt lantern battery, others have different methods.
I had to re-flash my neighbors little harbor fright generator a couple of times, it was one of those little $89 ones.
As far as your preconceived rectifier problem, they are easily tested if one has the knowledge.
If you are not a person with electrical experience, I would suggest you take it to a person that is, so you don't do more damage to it IF it indeed needs any kind of repair.
Without a schematic, it is pretty difficult to troubleshoot something electrical.
They were available in the day, for various equipment manufactures.
I think Deere offered them as an option, but not sure.
Google is always a good option for things unknown.
