Old 07-25-2010, 03:06 PM
tuneman tuneman is offline
Default newbe just bought a 85 1450
Hi all
needed a tractor ,Purchased one near me . Fellow told me its a 1985 1450
No books for it .How do i tell the year? I have the serial number for it and the deck. Is there a search i can do to get the year. I found it to be kind of jerky
when ingageing the hydro drive. Is there a fix for that! also found a filter
on some unit towards the back. No numbers on it . And where do i check the fluid that is being run through this filter. Wher do i buy the filter and fluid.
Where is the drain plug and filler plug. Pictures would help!! I have lots more questions . Hope theres lots of help here , I need it!!!
Old 07-25-2010, 03:22 PM
TEET's Avatar
TEET TEET is offline
Congrats on your new purchase! You can use the search feature to find answers to all your questions, and it would help to read the service manual as well.
http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 07-25-2010, 03:46 PM
First, welcome to our Forum.........
The model 1450 was produced between 10/74 to 09/79. A chassis Serial Number would identify the month and year of production.
The "jerky action" of the hydro can be a number of things. I would start by examining the linkages from the Hydro Handle all the way back to the Hydro Unit itself and see if there is any slop and worn parts.
There is a lot of information in our Technical Library. You may want to look through it.
Parts are available from your local Cub Cadet Dealer and our Fine Sponsors listed in the boxes at the top of the page.
Old 07-25-2010, 04:50 PM
Old 07-25-2010, 05:17 PM
camarokidz28's Avatar
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 07-25-2010, 09:14 PM
Glad to have you!
Old 07-26-2010, 07:24 AM
T-Mo's Avatar
T-Mo T-Mo is offline
As Roland stated - your 1450 is not a 1984, as IH stopped building the 1450 in 1979. Welcome to OCC.
