Old 04-26-2019, 10:10 AM
Gr8lite Gr8lite is offline
Default Proper wiring schematic ?
Ok Guys need a bit of assistance here .......I'm looking to find the correct wiring schematic for my SGT. Any / all help will be greatly appreciated.
model 1872
model # 149720100
ser# 791249
trying to resolve an intermittent issue and to also have one in my binder for future reference.
Thanks Much !
Old 04-26-2019, 11:33 AM
Check the e-mail address as listed in your profile.
Old 04-26-2019, 12:08 PM
Thank You Mr. Bedell !
However ....... how is it that the main wiring harness in my SGT that appears to be original has a number of GREEN wires that I cannot find on ANY schematic?
I have a green wire with an eyelet on it ( I assume a ground) just hanging around down near the starter neighborhood that exits the main harness just below the tank outlet "area".
Thanks !
Old 04-26-2019, 01:37 PM
Have you owned the Tractor since new...??
Old 04-26-2019, 01:53 PM
I have not , however there was one owner prior to me. A municipality , it was always serviced at the local dealer. If this harness is not original , someone did a bang up job replicating a factory harness.
Old 04-26-2019, 01:55 PM
Then someone modified the original harness. Follow the diagram I sent you and bring it back to where it should be.
Old 05-02-2019, 11:07 AM
Ron , check out these pics..... I don't believe that anyone has modified the original harness.
Old 05-02-2019, 11:17 AM
That wire bolts to the flywheel shroud.
Up to 534 and counting...
Old 05-02-2019, 11:46 AM
Thank You Sir , I guessed that it was a ground , but always best to confirm.
Old 05-03-2019, 07:20 AM
Default Almost at end of rope .........
OK still trying to find out why I have no power except at the battery !
Gotta start some where , so first things first. Please see attached pic of wiring schematic, note that I have circled the only 2 fuses shown.
Where physically are these fuses located?
I have one fuse holder in the dash to the left of the key switch (just replaced with new as original had shorted out, the apparent start of my electrical problems). I can't find the other that is shown.
I am guessing that fuse "A" is the fuse in the dash , ? correct?
I realize that the fuse for the lighting circuit doesn't affect the start circuit , but I'd like to know where it is.
Thanks in advance !
