Old 05-07-2019, 12:49 PM
King47 King47 is offline
Default Cub Cadet 106 starting issue
Hello,
I am in the process of restoring and using a cub 106. Anyways, it was running and then parked it in my garage and it wouldn’t start. I have replaced the voltage regulator, ignition coil, and have rewired it with a Hamilton Bobs harness. Anyways when I go to hook up the battery, it is trying to start. I am at a loss and have tried probably 30 variations of wiring. Not sure if it is a starting solenoid or something else. Any advice or suggestions is much appreciated.
-G
1971 Cub Cadet 106
Matt Gallagher
Old 05-07-2019, 01:58 PM
One of two scenario's. (A) the tractor isn't wired right, or (B) shorted V/R.
Go to the Technical Library Section and download the wiring diagram and make sure the tractor is wired correctly.
You say you replaced the V/R. Was that a Cub Cadet V/R..??
Old 05-07-2019, 02:53 PM
Merk Merk is offline
Originally Posted by King47 View Post
Hello,
I am in the process of restoring and using a cub 106. Anyways, it was running and then parked it in my garage and it wouldn’t start. Any advice or suggestions is much appreciated.
-G
Make sure we are on same page....was it running before you restored it ? Maybe I'm missing something
I had a 126 that had the same problem when I connected the battery....starter would spin. First thing I had to do is replace the wire harness. Make sure you follow the wire diagram in the tech section. Make sure your grounds have a good clean connection. 106 has several ground connections. Next thing I did was remove one wire at a time and tried to connect battery. My problem turned out to be a bad solenoid.
I've seam too many tractors have grounding/starting issues because fresh paint/poor-rusty grounds.
I've been adding an extra ground wire from the negative battery post to starter generator base. I also make sure the connection between the starter generator and bracket is free of paint and rust.
Project Uncle Dick
Cub Cadet 70
Old 05-08-2019, 03:14 PM
Thanks, I will check the wiring diagram in the technical area.
I it for about 2 months and it was Running but didnt start it much.
The v/r was based on the model # but not sure if it was a cub cadet part. I will double check but believe it was. I was trying to use oem parts.
There were frayed, corroded and exposed wires all over before getting a new harness/kit
1971 Cub Cadet 106
Matt Gallagher
Old 05-21-2019, 06:13 PM
I must be blind but I do not see any wiring diagrams in the tech area.. anyone have a link to a 106 wiring?
This thing is turning into a 700 lb paperweight in my garage.
1971 Cub Cadet 106
Matt Gallagher
Old 05-21-2019, 07:27 PM
The Wiring Diagrams are on Page #5 in the Technical Library Section and have been so for 12+ yrs.
Old 05-21-2019, 07:30 PM
cubs-n-bxrs's Avatar
Here ya go.https://www.cubcadetpartsnmore.com/u...wiring/106.pdf
