Old 05-08-2019, 05:42 PM
DieselDoctor's Avatar
Default Newer Cub - older deck
Is it possible to install a # 374 60" deck on the newer Cyclops? My 1782's serial range calls for a 325 deck, and you guessed it, I've got a 374. The deck and the mule drive are off of a 1772. I don't mind doing a little cutting and welding if needed.
Old 05-08-2019, 07:57 PM
Just change the pulley on the deck and be happy.
Old 05-10-2019, 02:27 PM
Thanks Sam. Will the mule drive and lift work as well? I've got one off of a 1772.
Old 05-10-2019, 05:33 PM
Yep, this is a 2182 I used to own. It came with the 325 and I swapped it for a 374
Old 05-19-2019, 03:12 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
You can always walk away from the deck, get drunk and be happy!
1- 1200 in pieces
1- 1864 in pieces
