Old 05-09-2019, 02:54 PM
rosefield rosefield is offline
Default RZT50 PTO does not engage
We have an RZT50 that was mowing the other day and everything was working just fine. Stopped to visit with a neighbor and when I started the mower back up and pulled the PTO switch, the blades do not engage.
In checking the mower, when i pulled on the belt the blades turn real freely with no resistance. Thinking the electric clutch went out, ordered a new on and installed it, but still fails to engage the blades.
Also replaced the PTO Switch, still nothing.
I have looked at the safety switches and they appear to be OK.
Any ideas?
Old 05-09-2019, 04:36 PM
Just throwing parts @ something is not a way to a repair it,as you have just learned.
I would suggest you check the wiring diagram to see why you have no power to activate the electric clutch.
Old 05-09-2019, 05:35 PM
We have power to the clutch
Old 05-09-2019, 06:30 PM
ejl6658 ejl6658 is offline
When you say you have power to the pto clutch are you measuring it with a voltmeter at the pto connector? Do you hear a click and see the pto clutch disk move?
Old 05-09-2019, 07:05 PM
Yes, we have power to the clutch and it makes a definite click to engage.
Old 05-09-2019, 08:24 PM
If the clutch is working then you have other issues like broken belts or idlers/tensioners that are not taking up the slack.
Old 05-09-2019, 09:56 PM
X2 with ol George's diagnosis.
Old 05-09-2019, 10:30 PM
How do you know the safety switches are good? I had the same issue and after replacing all 3 safety switches, everything is just fine.
Old 05-11-2019, 11:55 AM
Finally figured it out. Somehow when I put the belt back on when I pulled the PTO switch, it wedged the belt at one of the idler pulleys. I had turned the belt and it had moved ok when I rolled it onto the PTO clutch.
Readjusted the belt and mower is working great. The PTO clutch had gone out and the new one sure made a difference.
If anyone should be interested, the new clutch we ordered from oxclutch.com and was almost 1/4th the cost of the one from cub cadet.
Wondering what a new clutch from cub cadet looked like, when the too it out of the box it was identical to the ox clutch.
