Old 05-12-2019, 06:35 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default 1572 Surprise
This weekend, the 1572 I have owned since 1987 gave me a surprise. I started it up to do some spring yard work. While it started fine, soon after starting the ammeter started bouncing around showing a large discharge. I shut it down as soon as I saw this happening. Following the wisps of smoke I could not see when the fan was running, I found a short circuit. This was at the top left corner of the dash by the ammeter. The screws that mount/hold the dash panel are self-tapping screws. When I removed them, I was surprised to see the self-tapping screws had extremely sharp points on them like a nail and their long length extended right into the wiring harness that runs right past this point. It was strange to see that it took so many years to create a problem. I went and checked my 1772 to see if it was ok. The dash screws on it had blunt/flat tipped screws that were a little shorter, so it probably won't be a problem this that.
In the mean time, I ground a little off of the 1572 dash screws, removing the sharp point and making them a little shorter n the process.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
