Old 05-15-2019, 01:15 PM
semper fi's Avatar
semper fi semper fi is offline
Default 48" deck baffle
I have a mower deck off of a 129 that doesn't have any baffles. Should it? Deck is a 483-U-1111. If it needs one, does anybody know where I could find one, or a part number.
Old 05-15-2019, 01:33 PM
cooperino's Avatar
All of those style decks had baffles. if yours are missing and the deck is still good the best thing to do is bend up some steel and weld in one you fab.
Old 05-15-2019, 01:44 PM
cooperino's Avatar
Heres a link to a thread an OCC member posted of his 48" deck rebuild. Has pictures of the baffles so you can see what it should look like
https://www.onlycubcadets.net/forum/...ead.php?t=6773
Old 05-15-2019, 08:46 PM
mortten mortten is offline
The 1963 to 1968 decks have a 2 piece baffle. They are NLA. 1968 to 1971 have a 3 piece baffle. The outer sections are available at about $100.00 each. The center is NLA. 1971 to 1973 have no baffle. This is according to the parts look up.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 05-17-2019, 07:33 AM
semper fi's Avatar
I can see the welds where the baffles were. My question now is how wide should the steel be, if I have to try and fabricate them. And, does someone have a template?
Old 05-17-2019, 10:19 AM
cooperino's Avatar
1/8" X 1.75 or 2" flat stock is more than ample. If i were doing this I would just run through slip roll until I had a close radius to the old weld marks. It doesn't need to be real precise as long as the blades have clearance. If you don't have a slip roll you could find something solid with a similar radius to bend it around.
Old 05-17-2019, 10:48 AM
semper fi's Avatar
Thank you, you guys are super! I don't have a slip roll, but I'll figure something out. One more question, are these baffles one piece, or are they three separate
pieces?
SF
Old 05-17-2019, 10:57 AM
cooperino's Avatar
pieces?
SF
I don't really recall, Been awhile since I had one with original baffles in it I would make it in 3 pieces though and finish by welding where the meet together with a small opposite radius.
Old 05-17-2019, 11:01 AM
semper fi's Avatar
I was thinking that would be the easiest. Thanks for the conformation.
SF
Old 05-17-2019, 03:26 PM
ironman's Avatar
ironman ironman is offline
The baffles are not welded in. The have little 90 degree brackets welded to them and they are bolted (1/4" I believe) to the deck. What you are assuming is weld is probably the rusted remains of the bolt.
