Old 05-18-2019, 10:35 PM
Woodtrucker Woodtrucker is offline
Default Mowing deck
Thanks have a cub cadet 100. Guy wants to give me a cc73 deck. Will it fit my 100? Thanks
Cub Cadet 100 #66758
Old 05-18-2019, 10:54 PM
cooperino's Avatar
73 is the tractor model number. What model deck does he have?
Old 05-19-2019, 09:48 AM
sawdustdad's Avatar
May have some minor issues to deal with moving a deck from 73 to a 100. The 73 has a quick attach arrangement for the mule drive, the 100 does not. So the mule drive will not just clip on the 100 as it does on the 73. If you can get a mule drive for the 100 or modify the QA mule drive, then you can get the deck running on the 100. That's probably the only hurdle.
Remember, you need the deck, the support/lift frame and a mule drive unless you have those parts already for your 100. If you do and only need the deck, all the triangular shaped decks are pretty much interchangeable.
Old 05-20-2019, 08:48 AM
IHinIN IHinIN is offline
A QA mule drive will bolt onto the 100. I had one on my 100.
File Type: jpg BC417AE0-797E-4324-8E1B-76092740FCD9.jpg (35.3 KB, 144 views)
Old 05-20-2019, 09:10 PM
sawdustdad's Avatar
That's good to know, thanks for adding that. I have a 123 but no mule drive for it, but lots of QA mule drives.
Old 05-20-2019, 09:42 PM
Actually, I have a mule drive (currently in my shed) that came off the 100.
I also have a pivot hanger so I may have everything I need.
I have a 482-U-1113 deck. Just found serial number. All it seems to need is one spindle, set of blades, and a tension spring and I might be in business!
Old 05-20-2019, 10:07 PM
sawdustdad's Avatar
That's a 48 inch deck. Should all fit up fine. May be a bit much for 10 hp, but will still work.
Old 05-20-2019, 10:58 PM
Looks like this is the only thing that doesn’t mate up.
File Type: jpg F04746DD-0A66-4B42-81A8-6148A671AC9F.jpg (14.5 KB, 122 views)
Old 05-21-2019, 10:01 AM
That mule drive is for a "pin on deck"
Old 05-21-2019, 09:42 PM
Is it possible to use it by just grinding off the pins? Seems like it would work otherwise.
