My cub 127 blew up this past fall I found a donor tractor that has a nice running k301 it's a cub 125 , however the PTO in the 125 donor needs rebuilt and the PTO on my blown up 127 is good. I'm going to remove the PTO off the 127 and put it on the new motor. I cant figure out how to get a Allen wrench down into the hole that the set screws are in. The PTO shield is not lined up with the slotted tooth above the set screw hole. I don't want to strip out a set screw down there, forcing a wrench in there not square. Any tips ??
I tap the button with a soft hammer lightly while gripping the pulley with my hand to turn it to align the hole with slot.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
You need to get it to turn until they line up. Make sure once you get it aligned to use plenty of penetrating oil on all of the set screws. there are 2 set screws in each hole. TAKE YOUR TIME!
Put a three jaw puller on in. Tighten the center lightly and turn it.
Steven __________________________________________ 127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720. |
As mentioned, you can rotate the clutch until the cutouts line up. Lots of penetrating oil and take your time. If you rotate each set of set screws so they point upward, you can fill the hole with PB Blaster and let it soak.
I got the set screw out of 2 of the 3 holes the other one has been in on blaster for days and I cant get it to budge ..but were making progress thanks for all the help !
Its always the last one that gives the most trouble
You will get it
#2, a pin punch that just fits inside the set screw allen pocket, hit smartly with a hammer, usually jars it enough to loosen it, or help get it started. Also a person can use a allen wrench cut off so it substitutes as a punch if you don't have one, holding it with a pair of vice grips, makes it easier on the fingers/hand while keeping turning tension on it while hitting. If all fails, they can be drilled out but it is a pain, and a last resort. |
If all else fails before drilling and it had not stripped yet, you can try an impact driver with correct Allen 3/8 socket.
Not an impact gun... impact driver that you hit with hammer
