Old 05-24-2019, 12:15 PM
flametamer flametamer is offline
Default 1512 eating fuel pumps
Other than getting 2 bad pumps in a row (of 2 different styles), what could cause the fuel pumps on a 1512 to go out within 2 hours of run time? It runs fine until the pump quits.
Dt
Old 05-24-2019, 12:30 PM
cooperino's Avatar
Is it Vacuum type? Or electric?
Old 05-24-2019, 12:39 PM
Oem or aftermarket?
Up to 534 and counting...
Old 05-31-2019, 10:25 AM
Electric, aftermarket.
Old 05-31-2019, 10:58 AM
Aftermarket pumps with the wrong specifications.
Old 05-31-2019, 09:41 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
How are the pumps failing? I thought I had a run of bad fuel pumps on a 1512 I once owned. I would be mowing, then the engine would start missing and die, starving for fuel. I removed the hose on the output of the electric pump, turned the key on and nothing came out. I replaced the pump, it ran fine (or so I thought) for the rest of the season. Following spring, it started doing the same thing with a new pump. No output on the electric pump in the same way. I found I had a plugged filter screen on the valve in the tank. I ended up pulling the tank, washing it out and replacing all filters and hoses. Never had a problem again.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
