Old 06-18-2019, 02:21 PM
Sadavis Sadavis is offline
Default A new to me 1200
Hello everyone and thank you for adding me!
I recently picked up a 1200 model built in 1976. Its in good shape over all and runs well. Until today. I was mowing when the engine rpm went through the roof. I powered it down and found that the threaded brass insert for the governor had worked out of the block. I put it back in but I can't get it adjusted properly. It's either too tight and i have no throttle control or its loose and it over revs. I'm having a hard time finding instructions on how to do it properly. Any help would be greatly appreciated. Thanks in advance!
Old 06-18-2019, 04:16 PM
Welcome to OCC!
Old 06-18-2019, 06:19 PM
Welcome to OCC.....
The K Series Service Manual is in the Technical Library Section.
You may have a bad Governor.
Old 06-18-2019, 06:27 PM
twoton twoton is offline
.....You may have a bad Governor.
What he said.
The brass nut does not control the governor.
Here's a screen shot of the procedure to reset the governor but it sounds like your problem goes deeper than that...
Old 06-18-2019, 11:00 PM
Originally Posted by twoton View Post
What he said.
Thanks for the info, do you know if the brass nut should be tight in the block?
Old 06-19-2019, 06:03 AM
On page 12.1 of the Kohler engine service manual it lists the torque values for the various model engines. You can find the link to the manual on page 3 of the 'Technical Library - Tractors' section of this site.
The bushing nut on a K301 should be torqued to 100/120 inch pounds.
