Old 07-01-2019, 08:31 PM
thecause17 thecause17 is offline
Default Picked up my first Cub Cadet
I bought this '77 1650 on Friday. I have some work to do but am hoping to be able to mow with it this week-end.
https://www.youtube.com/watch?v=eUxM1E---Mc
Old 07-01-2019, 08:38 PM
sawdustdad's Avatar
Those are nice machines. May need some TLC on engine mounts, drive line, change fluid and filter and a general tune up. Looks complete and not badly abused.
Old 07-01-2019, 09:02 PM
Congrats on the 1650. I watched your video and in the intro, I saw a Super Tomahawk chipper. I have that same chipper.
Jeff
Old 07-01-2019, 09:58 PM
What he said...
Nice find at least it runs, just needs some TLC
Up to 534 and counting...
Old 07-01-2019, 10:41 PM
IHCubCadet147's Avatar
Congrats on your first Cub, I think you will really like it.
Old 07-03-2019, 10:36 AM
I was a little curious what I was watching when I saw the wrong colors come up, but then I saw that you got it right with the yellow & white!! Looks like a good cub and it runs!! Congratulations on your first cub cadet. Hope your mowing is goes smoothly. Of course, you are going to grease your fittings and check your shrouds for mice nest beforehand, since it has been sitting a while.
Old 07-03-2019, 07:23 PM
93Tim1440 93Tim1440 is offline
I had a '79 1250, very similar to yours. The only thing I didn't like about it was being a Hydro, it would run away on the downhills - freewheel - making it necessary to brake. This, of course, would move the Fwd-Rev lever and you would have to reset it. This was the only complaint I ever had with mine.
My second Cub, a 1440, holds downhills and doesn't have this trait. Of which I am very happy.
Good luck with your tractor, it will run for many, many years with the proper care.
Old 07-03-2019, 07:56 PM
budscub's Avatar
budscub budscub is offline
Default run away
Most of the "run away" can be corrected when the trunnion is repaired. I have a 1650 & 1450. that I have repaired the trunnion, replaced the springs and removed the play from the linkages and they do very well in holding their speed up and down hills. Very little to no lever adjusting while on hills.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 07-03-2019, 08:42 PM
Jeff
Yeah I picked that up a while back, just used it the other day, works really well. I have a couple of videos on that too, check it out if you have time.
I put new points/condenser and a new plug in it tonight. Tomorrow it's getting the new ignition switch to correct the charging issue. I should have new valve cover gaskets on Friday to fix the oil leak. After that it should be ready to mow.
Old 07-04-2019, 07:54 AM
ironman's Avatar
ironman ironman is offline
Have you actually traced the oil leak to the valve cover gaskets?
