Old 07-07-2019, 02:31 PM
Cub70's Avatar
Cub70 Cub70 is offline
Default Cub 70 42” Mower Deck Restoration Complete
Just finished a full restoration of my 42” rotary mower deck. I removed every part individually and cleaned, sanded, primed, and painted them. 6 new spindle bearings, 6 new seals, 3 new spindle bolts/grease fittings, 1 new idler pulley, new blades (on order), 2 new 7” steel deck wheels, 2 new deck wheel mounting bolts, new grease-able idler pulley mounting bolt, 1 new Kevlar 77”x1/2” belt
Before:
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer
Old 07-07-2019, 02:32 PM
Cub70's Avatar
After restoration picture:
Old 07-07-2019, 02:33 PM
Cub70's Avatar
After restoration pictures:
Cub70's Avatar
Old 07-07-2019, 02:34 PM
Cub70's Avatar
Old 07-07-2019, 03:50 PM
Great job on the deck!
Old 07-07-2019, 03:53 PM
Cub70's Avatar
Thank you!
Old 07-07-2019, 04:52 PM
IHinIN IHinIN is offline
Nice work. It looks like you had an unusually nice deck to start with. Most of those early decks are full of rust holes.
Old 07-07-2019, 06:09 PM
Cub70's Avatar
Yep, it was only surface rust and no holes. I did have to make the 1” hole in the right hand pulley cover to allow the grease fitting to stick through for the upgraded idler pulley mounting bolt.
Old 07-07-2019, 06:35 PM
twoton twoton is offline
Great job on all the parts! Thanks for the pictures.
