Old 07-07-2019, 03:59 PM
Cub70's Avatar
Cub70 Cub70 is offline
Default Cub 70 PTO clutch & Mule drive restoration complete
Finished the PTO clutch rebuild and restoration. All new parts other than the housing and back plate. I also finished the mule drive restoration too.
Before:
1964 Cub Cadet 70 (Full Restoration), Upgraded/Rebuilt K181 8hp engine, custom exhaust stack/flapper, NEW clutch, brand NEW steering column, Custom made wiring harness w/ammeter, LED headlights and tail light, Custom 2” receiver hitch, Custom pull behind paint matched trailer
Old 07-07-2019, 04:00 PM
Cub70's Avatar
After restoration pictures:
Old 07-07-2019, 04:01 PM
Cub70's Avatar
Cub70's Avatar
Restoration pictures
Old 07-07-2019, 04:17 PM
Great job!
Old 07-07-2019, 04:22 PM
IHscout79 IHscout79 is offline
YEAP! Great job! Looks good!
Justin
Old 07-07-2019, 04:36 PM
Looks real good.
Old 07-07-2019, 06:04 PM
Cub70's Avatar
Thank you for the compliments!
Old 07-08-2019, 06:22 AM
FYI
For the pin on deck, the eye bolt holes will probably be too big.
I welded a short piece of 3/8" bushing stock into mine to shim them down to 3/8" to fit the pins on the mule drive.
I also drilled all the holes in the mule drive oversize and tacked a short piece of the proper size bushing stock in those and replaced all the pins where needed.
Makes for a nice tight setup when finished and my deck mows like a new one leaving a near perfect cut.
Old 07-13-2019, 08:08 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default what a great job
you should really be proud of that!
Super nice!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
