Old 07-08-2019, 07:16 PM
jknight jknight is offline
Default 1211 fuel pump
I believe the fuel pump on my 1211 has gone south. I see cub wants an arm & a leg for theirs. Has anyone had good luck with the aftermarket pumps? If so, can you give the website where you got it?
Thanks
Jeff
Old 07-20-2019, 07:54 AM
I replaced the fuel pump on the 1211 but it doesn't pump gas. If you pump it by hand it pumps gas but mounted to the engine it doesn't. Could the pump follower in the engine quit spinning?
Thanks
Jeff
Old 07-20-2019, 07:59 AM
Is there a place to download the Kohler manual TP-2203-A?
Old 07-20-2019, 08:06 AM
The 1211 came with a Kohler M12 471512 engine. Basically the same as the K Series except Magneto Ignition.
IIRC, there is a cam that the Fuel Pump Lever rides against to produce the pumping. I suppose it is possible the cam wore. I would think the lever being the softer of the two metals, the cam would win that battle. You can stick some metal rod in the Fuel Pump mounting hole, and see if the rod moves up/down as you rotate the engine by hand to verify.
You can always go to an Electric Fuel Pump also.
Old 07-20-2019, 08:15 AM
Thanks for the reply Roland. Is there a specific electric fuel pump? Will try the rod to see if it moves.
Old 07-20-2019, 08:18 AM
This one emulates Kohler specs....
Old 07-20-2019, 08:23 AM
The Fuel Pump diagram is on page 6A.3 of the Service Manual.
Old 07-20-2019, 08:33 AM
Thanks again Roland. I think I will go the electric fuel pump route. That looks like the one I put on my JD322.
Old 07-20-2019, 08:53 AM
Thanks
Jeff
That happened to me sometime back. I wound up taking the old and new pump apart, used the pump arm off the old pump and put it back together. It worked.
Old 07-20-2019, 09:40 AM
First, does your old pump, pump fuel when removed from the engine like the new one?
Next, IIRR the Camshaft has an eccentric lobe that actuates the fuel pump.
The pump has to be installed properly so the cam lobe can do that.
if it is placed wrong, the cam cannot move the pumping lever.
This old man cannot remember if the lever goes on top or under the cam.
but a little investigation on your part should reveal the proper way it goes as there will be a wear mark on the old pump where it had been working in the past.
Now lets not get all excited about an 'lectric fuel pump when the mechanical
one will do it's job once the problems are sorted out.
It is rare that a hardened cam lobe plum wears out like the old ford flatheads did in pre '53 days
