Old 07-21-2019, 08:00 AM
jerry tracy jerry tracy is offline
Default My new 1863
Just bought this Friday. 443 hours and really clean!
File Type: jpg 103E10F3-C2B0-4AA0-BEA1-08D8750F1D47.jpg (46.2 KB, 165 views)
File Type: jpg 4A44AD87-9610-45B1-84B0-0F74EAC68AC4.jpg (44.2 KB, 166 views)
Old 07-21-2019, 08:13 AM
Here’s a few more pics.
File Type: jpg 8851F906-FB7F-4654-A2EB-0F100BD23F82.jpg (42.8 KB, 165 views)
File Type: jpg 13178031-8A5C-465C-A8E5-34AE08247BA5.jpg (26.7 KB, 167 views)
Old 07-21-2019, 08:18 AM
CubDieselFan's Avatar
That is a good looking 1863. Very nice.
Old 07-21-2019, 09:17 AM
Nice.
Old 07-21-2019, 04:43 PM
Nice score on your 1863!
Old 07-28-2019, 01:57 PM
Well an update on my new 1863. Looks like I might have been snookered by someone unfortunately. I got it all cleaned up and was doing a little mowing with it today and after about 10 or 15 minutes I noticed the fuel pump vent was putting out a little oil. Then it started really coming out and it was running and dying. Start it up, it would run for a second or two and then die. Choke it and could get it to run for a few seconds longer but would eventually die. Finally got it to stay running and put it in the shop. I did go out the next day and it started right up and ran good. Guessing a piston or head gasket issue.
Old 07-29-2019, 08:21 AM
mickb72 mickb72 is offline
Why would you think it's a piston or head gasket? If your fuel pump vent is leaking, i think the fuel pump may be going bad. Pull both plugs to get an idea of how each cylinder is running. Mike
Old 07-29-2019, 10:57 AM
BTDT, fuel pump failure for a 20 + year old tractor is a very common thing.
Cub Cadet
Kohler Part Number 24-393-16. Fuel Pump PRICE$67.18 Someone at Cub is on drugs if they think these things are worth $67.18
https://www.amazon.com/CH17-CH25-CV1...a-713385093725
Fuel Pump for Kohler 24 393 16-S CH17-CH25 CV17-CV25 CH730-CH740 CV730-CV740 17HP-25HP Briggs & Stratton 808656 491922 JOHN DEERE LG808656 Honda 16700-Z0J-003 Kawasaki FH661V FD731V FH381V FH430V FH45
by HUZTL
Price: $6.98
I bought one of these for an 1864 that I fixed up. It should take you about 10 minutes to replace it.
Old 07-29-2019, 01:29 PM
Well the reason I think it might be something besides the fuel pump is because something is pressurizing the crankcase which in turn is forcing oil up the hose that runs from the crankcase and its puking a copious amount out of the vent screen. The only thing I can think of that would pressurize the crankcase is either a blown head gasket or a hole or crack in a piston and or a broken ring. And I just swapped fuel pumps from my other 1863 that does not puke oil and it did the same thing. Am I missing something else?
Old 07-29-2019, 01:37 PM
OK then check the breather under the air filter and run a compression test.
