Old 07-28-2019, 01:35 PM
MBY852's Avatar
MBY852 MBY852 is offline
Default Flywheel pulley problems
Well I started to look into what else needs done on my 127 and I saw that the Flywheel/starter pulley was loose. Not good! So after I took the belt off I was able to move the Flywheel fore and aft a good 1/4". And when I took the S/G off one of the 2 bolts holding it on was broke off inside. So I took the bracket off and got the bolt out. And i can see the Flywheel was chewing away the bolt head on the upper S/G bracket. I can hardly wait to see what lurks after I take the PTO off.
Well I was getting jealous watching everyone else working on there cubs so I didn't want to feel left out. To be continued!
https://www.onlycubcadets.net/forum/...attach/jpg.gif
Old 07-28-2019, 02:15 PM
MBY852's Avatar
I got everything off. PTO was really easy. I don't know if thats good or bad.
So here's what I see the right side of the keyway is flared on the top. The left side is fine. You can see that the key reflects that. When I rotate the key to put the full 1/4" on the bottom and slide the pulley back on it's tight. So with a new key I think that will be OK. Looking at the PTO from the bottom to the top something looks wrong. I can see the split ring is not right. Going to take the PTO apart now and see yet another problem. Heres a shot of the bolt head the pulley was rubbing
jpg.gif 20190728_134833.jpg (22.3 KB)
jpg.gif 20190727_193904.jpg (8.4 KB)
jpg.gif 20190727_193536.jpg (13.4 KB)
Old 07-28-2019, 02:37 PM
MBY852's Avatar
Well here's a surprise. The metal above the recess for the split washer just peeled away.
So now I need a pulley. This day just keeps getting better. At least that's not as bad if the keyway got really buggered up.
Guess a post in the wanted section is next for a PTO pulley. I'm really not going to be using this tractor for mowing anyway. I may just blast it and paint it and put it back on the way it is. I have my 2155 for mowing. I'll just be patient and one will pop up sooner or later. https://www.onlycubcadets.net/forum/...attach/jpg.gif
