Old 07-29-2019, 09:36 AM
CubRookie CubRookie is offline
Default Flywheel cover removal Cub 104
I was wondering if it is possible to remove the flywheel cover while still in frame. There is a tone of dirt/Grass build up and would like to pressure wash it out before starting the motor. Also the fins on the cylinder are slam full as well.
Old 07-29-2019, 11:21 AM
The only way to effectively clean the engine properly is the remove the engine from the frame, and remove the shrouds. Clean the engine up and reverse your steps.
What you are proposing is better than nothing, but far from totally effective.
