Old 07-29-2019, 05:56 PM
Banman Banman is offline
Default 1450 Parts Tractor
Considering a 1450 parts tractor for my 149...
Want to confirm -- the hydrostatic transmission is the same.
The tire sizes should be close or the same?
The 14hp engine from the 1450 will have the magneto behind the flywheel but will the engine still fit in/on the 149 and can I still use the S/G from the 149?
Will a 3pt hitch from the 1450 fit on my 149?
Thanks!
Old 07-29-2019, 07:32 PM
Yes
Yes
Wrong. The 1450 will have the Solid State Charge system vs the S/G.
Yes
Old 07-29-2019, 07:55 PM
Yes
Yes
Yes
A 149 will have external brakes, some later 1450's have internal so you will need to address the linkage issue.
Up to 534 and counting...
Old 07-29-2019, 08:58 PM
Good to know!
Old 07-29-2019, 09:00 PM
Yes
Yes
Yes
Right but...
Will the eng from the 1450 fit on the 149? I realize the iso mounts would be different but do the mount holes line up?
Can you remove the starter from the 1450 eng and use the S/G setup on the 149 if you swap engines?
Old 07-29-2019, 09:08 PM
Only if there are mounting holes in the block to mount the S/G.
Personally, I would adapt the 149 to the Solid State Charging system.
Old 07-29-2019, 09:14 PM
THEPATRIOT's Avatar
THEPATRIOT THEPATRIOT is offline
Why not fix up the 1450 also?
Old 07-30-2019, 08:59 AM
Too many projects as it is...
After discovering the cost of new tires a 1450 with good looking tires and a bad engine seemed like it might be a good source of spares...
The 149 being my first tractor/riding mower I've now discovered I'd like a bigger deck too -- the whole idea was to take a lot less time mowing the yard...
Old 07-30-2019, 09:08 AM
Thanks for pointing out the differences. The 1450 "smokes bad" so it sounds like the eng's rebuildable -- something I'd do over the winter months for "fun..."
I'm sure the solid state charging is better but --
My beloved UH-1H (Huey) also used a starter/generator (mounted on the transmission) not many vehicles do -- the simplicity still charms me...
Really appreciating the wealth of knowledge about these things here!
