Old 08-03-2019, 09:22 PM
Giddy Giddy is offline
Default 1650 Blowing oil out dip stick
pick up a 1650 from a guy that his dad bought new. He said it started blowing oil out dip stick it still ran but he parked it couple years ago . would it be a broken ring or some thing else?
Cub cadets models. 123, 1250, 3 -1450, 1650, 782,982 ,1711
Old 08-03-2019, 09:33 PM
Billy-O's Avatar
Billy-O Billy-O is online now
Start with cleaning crankcase breather and see what you achieve. Are you burning any oil?
Plow blade
#2 Cart
QA36 snowthower
Old 08-03-2019, 09:56 PM
I haven't mess with it yet . Previous owner said that it had been rebuild in the 90's
Old 08-06-2019, 12:33 PM
Has 120 pounds compression .
Old 08-06-2019, 12:36 PM
Crankcase breather is clean
Old 08-06-2019, 12:38 PM
Is it functioning correctly ??
Old 08-06-2019, 12:58 PM
I guess how do you tell ?
Old 08-06-2019, 01:11 PM
Do you have the Koher K Series Service Manual ??
Old 08-06-2019, 03:01 PM
That is about as helpful as saying it snowed sometime in Alaska in the past 25-30 + years.
"Rebuilt" has many meanings depending on who is telling the "story"
To some, it means it was worked on by someone, having no idea what was done or to what.
Or to others, things were cleaned up and repainted, or the carb. or fuel tank was cleaned.
Still others, it means something like a engine rebuilt including, but not limited to,
boring & honing the cylinder to the next appropriate oversize, turning the crank to the next undersize and fitting the proper bearing or rod replacement.
Replacing the valves and seats or reconditioning them.
Setting the clearance by the proper method
resurfacing the block & head or heads.
Etc etc etc.
No sense building a watch here, I think you get the idea.
Now download the service manual, as it is free here, and go systematically at
checking the crankcase breather as to if it is functioning properly.
Easy things first.
Is the dipstick launching into the hood? or just leaking/slobbering?
We need more info and not stupid stuff like "it was rebuilt 30 years ago"
Now lets "Giddy up" and do some detective work,
before guessing.
Please explain how you got #120 of compression, understanding that engine has a compression release?
Oh, " and they all ran when parked"
IIRR, they said the titanic was steaming along just fine, even the band was playing,---- just before it sank.
Old 08-06-2019, 03:54 PM
Screwe in compresion tester and crank engine over . Goes right up to 120 pounds . The dip stick moves up down a little when cranking
