Old 08-11-2019, 10:27 PM
ejl6658 ejl6658 is offline
Default 25HP Kohler V-twin head gasket
Wasn't paying attention when I took it apart. Which side of this head gasket goes towards the head?
Old 08-12-2019, 07:24 AM
Service manual says "Install a new cylinder head gasket, (with printing up)", I don't see any printing in your pics. You may need to call Kohler and ask them.
Old 08-12-2019, 07:42 AM
cooperino's Avatar
In most cases when not marked and can fit same both ways it doesn't matter which way you install it.
Old 08-12-2019, 07:54 AM
Leadslingingdaddy's Avatar
See if you have an imprint on the head or block in relation to the fire ring....
Old 08-12-2019, 09:10 AM
I'd put the wide part of the "fire ring" on the block.
Why? hell I don't know,
but a block has a chamfered edge and a head is flat.
so maybe the wider part would still seal good on a chamfered block.
I've seem gaskets installed both ways.
Some are very specific on orientation, others make no mention as either way is good.
Others can go only one way by design/ shape/holes.
look, thinking as I have said to see if there is a preferred choice.
also look at what you took off if factory installed, as there will be witness marks showing which way was up.
----Just some things to think about, and muddy the waters
Old 08-12-2019, 09:24 AM
ol'George you were correct. I manage to dig the old gasket out of the garbage and couldn't discern any witness marks, but the old gasket had printing on it and the service manual states "printing up" which would put the wide "fire ring" towards the block.
