Old 08-12-2019, 09:54 PM
phillijw phillijw is offline
Question GT 3200 differential lock problem
This mower is new to me but previously used. I inherited it from a person who died so obviously can't ask any questions about it. It works and mows pretty good but I noticed one feature isn't quite right and that's the differential lock pedal. It's always to the floor and not engaged. I checked the diff lock lever and it seems to click into position when I move it by hand, so that doesn't seem like a problem to me but I could be wrong. The cable itself doesn't seem damaged but it does appear to be too long or something because the pedal barely starts engaging it when it's to the floor, even after adjusting the little adjustment screw thingy. Any ideas on how I would go about diagnosing the actual issue and fixing it? If I need a new cable, any idea where I might get one?
Old 08-14-2019, 07:09 PM
James DeHaven James DeHaven is offline
Default GT 3200 diff lock cable
There's one on eBay currently for $28.
Old 08-14-2019, 10:23 PM
Is it normal for them to just kinda stretch a couple inches? Seems odd
Old 08-15-2019, 06:51 AM
cooperino's Avatar
No, they dont stretch. There should be a spring on one side however, that's what keeps the pedal up. My guess is something is bent or not connected correctly if the cable is in tact. Either that or someone installed a incorrect cable. Check that the bracket that holds the cable is tight and not bent opposite of the spring end. I'm assuming the actual lock lever is not bent and in correct rest position.
Tags
differential, gt3200
