Old 04-29-2009, 08:38 AM
T-Mo's Avatar
T-Mo T-Mo is offline
Default Sleeve Hitch Adapter and IHC's 3 point
Pardon my novice question here, but after viewing the thread on the attachments for a 100 and after picking up a 104 with a 3 point, I have a very novice question. What's the circle pin in the below photos? (I "borrowed" these photos from the aforementioned thread - I hope you guys don't mind!)
The white pin in this photo that's circled:
The yellow pin in this one:
Again, I apologize for my ignorance here and for borrowing the above photos.
Old 04-29-2009, 09:26 AM
The shaft that goes into the casting is what does the lifting.
The slots in the lift bars are so the implement can float. You can also use one that has holes not slots to change lifting height while not allowing float. Some guys even use chains to lift.
Hope that helps T-mo.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 04-29-2009, 10:11 AM
67hydro's Avatar
67hydro 67hydro is offline
T-MO
sleeve hitch lift pin.
Jason
Old 04-29-2009, 10:16 AM
MBounds's Avatar
MBounds MBounds is offline
T-MO: The white one is a lift and pin are the ones for that Original Model shown in the photo and the yellow one is from a later Narrow Frame tractor, also as shown.
The pins used with the Originals have a flange on them..The later ones do not...OEM pins are normally white. That yellow pin was painted by a PO just like the lift arm on that Original was painted white by the Owner. OEM, it was yellow just like the lift bar.....
Pins were not part of the optional lift assembly but were a required part of the accessory/implement which are almost always white. IH dealers would sell you a lift pin, if ordered, but did not supply them with the 3-pt lift kits.
Myron B
Old 04-29-2009, 10:31 AM
MBounds's Avatar
Smile
67Hydro: NOPE !...It's a 3-point lift pin!...It, in fact, will lift the sleeve hitch adaptor, but it also lifts a rotary tiller or a Brinly turning plow, disc, harrows, etc., etc., or whatever implement you have mounted there....
Myron B
Old 04-29-2009, 11:28 AM
Cub61's Avatar
Cub61 Cub61 is offline
Hey T-Mo!!!! How's it going good buddy!!!
T-Mo, you're more than welcome to borrow pictures of the OL' Girl anytime you want. By the way, thanks for using the OL' Girl as an example. That's pretty cool!!!Take care good buddy!!!!
MATT
Old 04-29-2009, 12:01 PM
T-Mo's Avatar
Since I'm on a roll of novice questions, one more. Is this what we're talking about? http://www.cngco.com/DisplayProduct.cfm?ProductID=1189
Matt,
Thanks for the use of that excellent photo. It sure comes in handy, especially to me.
Old 04-29-2009, 12:41 PM
MBounds's Avatar
T-MO: Yep. That is the same as the yellow pin in the photo's. Note: the Original uses a different cotter pin retainer hole location, so some drilling may be needed if an Original model is involved.
Myron B
Old 04-29-2009, 11:30 PM
T-mo,
I have both kind of pins and can get you measurements if you want. Just let me know.
Randy
1 100's
2 149's
1 73
1 2182
Old 04-30-2009, 08:24 AM
T-Mo's Avatar
Thanks for the offer, Randy. I might take you up on it. But, first, I need to score the sleeve adapter.
