Old 09-09-2019, 09:39 PM
Rwgarrison23's Avatar
Rwgarrison23 Rwgarrison23 is offline
Default Starter solenoid question. CC 124
I'm trying to gather up all the parts to do my electrical restoration for the tractor including all new wiring harness. I need help selecting the right solenoid for my machine. Is this the right one for my 124?
Old 09-10-2019, 04:25 AM
cubby102's Avatar
cubby102 cubby102 is offline
The new one on the website isn't the "correct" one for a 124. But it will absolutley work without issue!
Old 09-10-2019, 11:02 AM
Which one is the correct one?
Old 09-10-2019, 11:21 AM
cooperino's Avatar
If your asking what the actual part is the IH part number is Ih-1114532P
Cub Cadet sells that one for around 100 bucks I think. However, there are plenty of aftermarket ones that will work just fine. You should get use to looking up these parts in the manual or online.
Old 09-10-2019, 11:26 AM
cooperino's Avatar
Here is one from one of our sponsors that is aftermarket but built to same size spec etc as the original one.
http://www.pattonacres.com/aftermark...-part-435-008/
Besides that. You could really use just about any single pole solenoid you want. mounting and wires may attach a little differently but will certainly work fine.
Old 09-10-2019, 01:35 PM
johncub7172's Avatar
Yea I used a starter solenoid from a model 72 in my 1711 and works just fine! Even a solenoid for a 82 Ford F100 would work in your 124, and could be less expensive. Try the scrap yards for parts too.
Old 09-10-2019, 02:29 PM
And if you go to napa you can get a ford car or truck from the '60's sol
with 3 posts like your picture for less than $10.00.
As mentioned one with 2 small terminals will work fine, but you only need 1 small terminal to energize it.
Sorry I don't have a napa part number but you can go to napa online and pick one out.
Usually they are Echlin like an ST 82
Ebay 323899671279
less than $15.00
if I can find the echlin number I'post it.
Old 09-10-2019, 03:19 PM
Thanks guys, it doesnt have to be exact correct part. Just want a working one that will bolt in place.
Old 09-10-2019, 04:03 PM
napa ST73
napa ST74
napa ST76
any will work, might have to straighten the bracket. all less than $17
prices have gone up a dollar two ninty eight, over the years
