Old 09-26-2019, 10:02 AM
go_aggies's Avatar
go_aggies go_aggies is offline
Question Rearend plate seal
As I was looking through older posts about changing hydro fluid I came across a post from Jmech where he said to use silicone instead of the seal. My question is, was he referring to 100% silicone or was he talking about a different type of automotive silicone? I am working on a 1650. I tried to PM Jmech, but I guess he has left the forum. Thank you for your help.
Go_aggies
Old 09-26-2019, 10:23 AM
cooperino's Avatar
You can use black or orange RTV. Dont goop it on. All you need is a thin layer.
Pick it up at any part store, hardware store,
Old 09-26-2019, 10:38 AM
go_aggies's Avatar
Thank you, that is what I was thinking.
Go_aggies
Old 09-26-2019, 10:54 AM
Uh, I don't buy that. I use the gasket as Cub Cadet recommends and apply a thin film of sealant on both side.
Old 09-26-2019, 11:34 AM
cooperino's Avatar
Yeah.. I like the gasket there as well.. However I have sealed many diff covers with only RTV in the past when I had to. It should seal it fine. As a mechanic for many years, the way I learned is only use RTV or other sealants on removable part unless otherwise stated in the manual. The reason is, It can be a real pain in the ass to clean the part that's not removable say like in the case of a water pump or timing cover in a tight engine compartment.
Old 09-26-2019, 02:10 PM
johncub7172's Avatar
My personal belief is that if the part had a gasket from the factory, then I choose to use a gasket. I too, apply a thin coat of sealer to the mating surfaces. Once the fluid has been changed, I never suspect a need to open the cover up for many years. Again, not a debate, only my personal beliefs. The gasket is about $6 bucks and some change, and always in stock at the local dealership.
Old 09-26-2019, 04:09 PM
go_aggies's Avatar
After hearing everyone’s thoughts on the matter I guess I will go ahead and put the seal on as well. Thank you for your input.
Go_aggies
Old 09-26-2019, 05:32 PM
My opinion:
I'm old skool when nothing used sillykone, just gaskets.
That said,
while I have used gaskets as well as sillykone, both seal as intended.
Gaskets give a problem if the cover has been over tightened and not hammered back flat in the bolt areas.
And/or you over tighten the cover with the new gasket installed.
If you have flattened the cover, and want to use a gasket, do so.
If you want to use silly-kone instead, do so.
One caution:
when using any sealer, do make sure the surfaces are free of old gasket material and DRY of any lube/water/etc.
Clean with gas,lacquer thinner or brake clean.
Do not allow oil to seep out of the gears while applying the silly kone, because if surfaces are wet/contaminated you might as well as put a catch pan under it because it will leak.
silicone did not become popular till the 70's as a replacement for gaskets.
it is less expensive and yields itself easily to assembly line production methods.
As mentioned, a thin coating is desirable, less is better.
I do not use both silly kone and gaskets.
Old 09-27-2019, 07:28 PM
mortten mortten is offline
I use a gasket and #2 Permatex
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 09-27-2019, 08:15 PM
If using permatex or similar, use a small even bead and just snug the bolts with your fingers. After 10 minutes or so then snug them down. It helps it not squeeze out. If using a gasket, make sure the cover is flat and there is really no need for any sealant. It didn't when it was made.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
