This is my go to tractor for cutting grass. I bought this in 2015 and have used the hell out of it. But, alas it is a 1978 model and after 41 years an oil leak is not unexpected. Sooooo, in my two minutes of spare time I yanked the engine, washed it and dug in. The flywheel is tighter than tight and will not come loose...I will be successful. I keep upgraded cradle frames on hand ready for install. I will be using Cub Cadet ISO mounts rather than the solid ones. The drive line will be refreshed as needed. Also, before I forget, I bought a new Xtreme PTO clutch for it and can't wait to use this beast again. Now for the pics.
Queen Of The Quietlines!
You have been busy, but I and others look forward to seeing your progress.
Up to 534 and counting... I give up updating my profile! |
Looks like an interesting project Beth. Keep us updated as you proceed.
Good luck Beth
Doug Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift 1250 w/hydraulic lift, lights,weights, spring assist. 50C deck converted to an A with front wheels 44C deck converted to an A with front wheels. QA-36A 42" blade |
The flywheel yielded to my gentle persuasion
. Inspected the seal but it was not leaking. Removed the stator and bearing plate and found the shim gaskets had failed. I replaced the gaskets, seal and oil pan gasket. Pulled the cylinder head and found the usual stuff and decided to do a valve job too. All went well until the PTO clutch. Bought this from CCSpecialties and went to install it. Oh Snap! Correct part number, wrong part in box. Oh well shit happens. It does not fit appears to be for an 82 series. Called Charlie and got the situation handled....new one is on the way! The Xtreme clutch looks like a fantastic one ...very well designed and built...looking forward to the correct one. The saga continues. Pics or it didn't happen.
Looking good! Glad to hear it's on its way to recovery
IH cub cadets 800x3,1000,1100,1200x2,1250DS,1450,1650DS, 71,122x2,123, 73x2,106,107,126x3,127,147x2,86x3,128,149, 169x2 ,Original, cadet 55, to name a few CCC machines 1282,1050,2072,1535,1440 |
The 1650 is all better now.
Looks good... and I'm a 1978 model, and I'm not leaking anything. (yet)
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Looks good.
Good fix. Nice job.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
