Old 10-03-2019, 02:28 PM
jzidle jzidle is offline
Default Driveshaft on a 123
What's the easiest method anyone has for removing/replacing a driveshaft on a 123? Thanks!
Old 10-03-2019, 08:26 PM
Billy-O's Avatar
Billy-O Billy-O is online now
When I replaced the driveshaft on 125, I did what this other forum member does: https://www.onlycubcadets.net/forum/...6&postcount=19
It's a good way to clean the crud off outside of the pump while you're at it. Inspect the linkage and swash plate, too!
Plow blade
#2 Cart
QA36 snowthower
Old 10-26-2019, 11:23 PM
steelsmith steelsmith is offline
When I got my 123 it had been setting in a barn for over 10 years so I did as the post above said and pulled it in two and as long as I had it that far apart I took the back cover plate off, cleand out all the oil and gunk the was in the case, then I drilled and taped a drain hole in the buttom of the case. as long as I hade the back cover off and the drill and tap set out I drilled and taped a fill hole on the top of the case.
I also placed a small magnet insaid the case near the drain hole jest becouse I had one and the case was open.
I put it all back together and filled it up to the fill hole on the back cover plate , so now when/if I need to change Hyd oil in it I can do so with out pulling the back cover off.
Joe
