Old 10-06-2019, 12:04 AM
Merk Merk is offline
Default Narrow frame hydraulic system on an 147
I'm helping someone with a IH Cub Cadet 147.
Has anyone installed a narrow frame hydraulic system on an IH Cub Cadet 147?
Any usual problems-mods that need done to make it work?
Thanks
Merk
Project Uncle Dick
Cub Cadet 70
Old 10-06-2019, 09:02 AM
I know the 147 typically used their Electric Lift. I but can not see why the NF Hydraulic Unit wouldn't work.
Keep us posted on this project.
Old 10-06-2019, 01:34 PM
Owner claims a 147 requires modification of the driveshaft due to the exterior flywheel screen. Then He was told that the cylinder bottoms out on the lift side due to clearance issues.
This 147 has a manual lift. Owner wants to upgrade to a electric lift. He is having problems finding one that works and in his price range.
I have an off topic garden tractor that strip gear in the electric lift. Dealer wants $515 for a new gear.
Project Uncle Dick
Cub Cadet 70
Old 10-06-2019, 01:49 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Maybe this can help...
https://www.mcmaster.com/actuators
Then select electric actuators.
Queen Of The Quietlines!
Old 10-06-2019, 01:53 PM
Merk,
I have never put a hydraulic lift on a 147, but he should be able to loosen the engine by removing the engine mounting bolts. Remove the driveshaft cover, and with the hydraulic lift mounted on its bracket, set the belt on the pulley behind the shroud and on the pulley on the hydraulic lift. Pull it taut and align it that way. Once he finds the mounting position, mark the holes with sharpie (since he may need to drill into the frame). Set the hydraulic lift unit and then the cylinder can be adjusted as needed. If he has to re-locate the cylinder so that it doesn't bottom out, then could adjust that or if he has to, leave the Armstrong lift on the cub, put it in the float position and link the cylinder bracket to an Armstrong lift (paddle) bracket. This may require him to modify or adjust the mounting bracket for the cylinder of the hydraulic lift.
He may also be able to use the correct rockshaft for the hydraulic lift, which would be the best case scenario.
Old 10-07-2019, 10:08 PM
Check out this thread:
https://www.onlycubcadets.net/forum/...ad.php?t=27571
This is where the conversation came from that I didn't think it would work (or I'd have one already, a NF hydraulic lift would look BA on a 147 IMO.)
